[Rower] Eurobike?
Witam.
Czy ktos sie orietuje cos o rowerach tych firmy ?? Dzieki za opinie...
Pozdr.......
                                                 Eurobike
                    Front Fork Type:Spring Fork (Low Gear Non-damping)
Gears: 27 Speed Gender: Men Frame Material: Aluminum Alloy Pedal Type: Bead Pedal Net Weight: 17.5kg Frame Type: Hard Frame (Non-rear Damper) Foldable: No Rim Material: Aluminum Fork Suspension: Yes Fork Material: Aluminum Alloy Stature: 150-180cm Type: Mountain Bike Wheel Size: 26" Applicable People: Unisex Load Capacity: 200kg Braking System: hydraulic disc brake Length (m): 169cm Gross Weight: 20
                                                Crosstar Bike
Front Fork Type: Oil Spring Fork (Spring Resilience/Oil Damping) is_customized: Yes Gender: Men Frame Material: Aluminum Alloy Brand Name: Brand Braking System: Double Disc Brake Pedal Type: Bead Pedal Length (m): 1.4 Net Weight: 14kg Frame Type: Hard Frame (Non-rear Damper) Foldable: No Rim Material: Magnesium Alloy Fork Suspension: Yes Fork Material: Aluminum Volume: 0.03 m3 Stature: 160-185cm Type: Mountain Bike Wheel Size: 26" Applicable People: Unisex Gears: 30 speed Load Capacity: 180kg Gross Weight: 25kg
                                         Laucx Jack
Gender: Men Gears: 24 Speed is_customized: Yes Frame Material: Aluminum Alloy Brand Name: SAEQ Braking System: Double Disc Brake Load Capacity: 160kg Pedal Type: Ordinary Pedal Size: 52cm(175cm-180cm) Length (m): 1.4 Net Weight: 17.5kg Frame Type: Hard Frame (Non-rear Damper) Foldable: No Rim Material: Magnesium Alloy Fork Suspension: Yes Stature: 150-200cm Volume: 0.1 m3 Fork Material: Aluminum Alloy Type: Mountain Bike Wheel Size: 26" Gross Weight: 18kg
              XDS2015 Sundance
Frame: XDS X6 aluminum alloy
Size: 26 "x 15.5" / 17"
Front fork: Suntour XCT aluminum alloy front fork with hydraulic lock
The transmission system
Variable speed handle: Shimano M370
Before the transmission: Shimano M370
After the transmission: Shimano M370
Brakes: Shimano 355 hydraulic disc brake
Tooth plate, aluminum alloy tooth plate
Wheelset system
Circle: aluminium alloy double knife circle
Tire: CST 26 "x 1.95"
Gość HydraulicznyCyborg
18-25 kg to ciężarówka. W żadnym wypadku nie kupuj takiego kowadła.
Zobacz jakie są dopuszczalne obciazenia200kg? To rowery dla Pudzianowskego
Opisy ktore sa przy tych rowerach to tylko przyklad bo sa  ramy ktore maja np 14kg ja dalem tylko tak czy ktos zna te marki i jezdzil nimi....
jeżeli chodzi o rowery Eurobike: eurobike.pl, to ja jeździłem około 1,5 roku na tym:
http://www.eurobike.pl/rowery-eurobike/rowery2013/mtb29er#agg
rower jak rower, w takim przedziale cenowym około 1500 zł, wszystkie są mniej więcej podobne, mają atrapę zamiast amortyzatora itp.
jak go kupowałem to wydatek rzędu 1,2 tys. za rower wydawał mi się kosmiczną kwotą, służył mi dzielnie przez ten czas, z ramą nic złego się nie działo,
napęd, klamkomanetki, tylną przerzutkę, opony(waga jednej około 900g  :woot: ) wymieniłem, ale to normalne, zużywa się - zrobiłem na nim około 8tys. km, dobrze mi służył
w tym roku wydałem 2,5 razy więcej na nowy rower i jeździ mi się na nim jeszcze lepiej
jak wkleisz link do interesującego Cię roweru to na pewno będzie można więcej powiedzieć o konkretnym modelu.
to zupełnie inna bajka mój "Eurobike" i Twój "Eurobike"  - więc przepraszam, że się udzieliłem w tym temacie
ale z tego  opisu nic nie wynika, nie można ocenić jak jest wyposażony rowerek
Pierwszy mój rower jaki sam kupiłem to był własnie Eurobike Agressive.
Nigdy na niego nie narzekałem, większych problemów nie miałem. Mimo mojej szaleńczej jazdy z ramą nic sie nie stało.
Przecież to jest chińszczyzna. O wiele lepiej brać lazaro kands z normalnej polskiej dystrybucji
Jest tam pelny  opis roweru interesowal by mnie DELUXE z tego co tam widac to chyba nie jest jakos slaby rower....
Określając jednym słowem: padlina.
Ten luksus ma trzy markowe części, mimo wszystko niskiej jakości.
Ile ma Cię kosztować to coś, wliczając koszt przesyłki i cła?
A z przesyłka ?Subtotal: € 418,65 Shipping: € 233,70Total: € 652,35
~2600 zł dodaj 23% vat i cło.
Nie no super deal  :teehee:
Kolega wyżej ma racje - padlina ;)
