Gość remika Napisano 23 Lipca 2009 Udostępnij Napisano 23 Lipca 2009 Czy możecie ocenić tego Schwinna? BOTTOM BRACKET: VP semi-cartridge square JIS taper BRAKES: ProMax linear-pull brake with 60mm pads CASSETTE: DNP 7-speed, 13-28T CHAIN: KMC Z-51 CRANKSET: Schwinn Approved forged Alloy by Prowheel, 24/34/42T Rings in a 152mm length FORK: Trail-Tuned MA-179 Suspension Fork w/ Alloy Crown, 50mm Travel FRAME: Schwinn N'Gauged Hi-Ten Comfort with Trail-Tuned Geometry FRONT DERAILLEUR: Shimano TY10 GRIPS/TAPE: Schwinn Approved single density Kraton rubber HANDLEBAR: 40mm rise, 6 degree bend HEADSET: 1 1/8" threaded LEVERS: ProMax Alloy w/ reach adjuster PEDALS: Resin body, Steel axle REAR DERAILLEUR: Shimano Tourney TX31 REAR SHOCK: NA SADDLE: Trail Tuned w/ two tone cover SEATPOST: Alloy Micro-adjust SHIFTERS: SRAM MRX 204 indexed STEM: 25 degree rise quill stem with front load Alloy cap TIRES: Trail Ready 26 x 1.95" WHEELSET: Rims: Weinmann TM-19 Alloy; Hubs: Formula Alloy sealed mechanism, QR front and rear Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Pytanie
Gość remika
CHAIN: KMC Z-51
REAR SHOCK: NA
0 odpowiedzi na to pytanie
