emski Napisano 14 Kwietnia Napisano 14 Kwietnia (edytowane) Jak w temacie, nówka - 550 PLN Specifications Eye to eye / Stroke 190x40 Air volume Solo Air Remote TwistLoc 3 pos remote sold separately Hose length/Cable Exit Out Pull Model designator (SR) Ultimate Damper Type RLR Rebound tune R29 Compression tune C25 Pedal tune MD Lockout force X8 Color (Shock body)Black Color (Decal) Blue Decal orientation A Shaft Eyelet Standard Body Eyelet No Bushing - 90 Deg Rotation Damping adjustments Extl rebnd, 3 pos remote (open/pedal/lock) Volume reducer 0 Tokens – No Eyelet Volume Spacer Check Tune STD E-Bike Approved Rebound Clicks 11 Max Air Pressure (PSI) 325 Bottom Out n/a High Speed Tune n/a Edytowane 14 Kwietnia przez emski
