Marcinkkk Napisano 18 Czerwca 2014 Napisano 18 Czerwca 2014 Witam was przymierzam sie do zakupu dwóch rowerów dla siebie i dziewczyny. Nie mogę nic ciekawego znaleźć dla dziewczyny. Jesteśmy na razie w Angli, i tu szukamy pojazdów. Nasz limit to 600 (3000pln) na każdy rower. Mój wzrost 180cm , waga 80. W okolicy znalazłem takie rowerki : Gigant talon1 2011: Cena: 550£ Frame AluxX aluminium, Fluid FormedTM Forks RockShox Dart 3 TK, aluminium steerer, 100mm travel Rear Derailleur Shimano XT Shadow Front Derailleur Shimano Deore Shifters Shimano Deore 27 speed Chainset Shimano HG73 Bottom Bracket Shimano Octalink Chain Shimano HG73 Freewheel Shimano HG50 11-34 Stem Giant Connect Handlebars Giant Connect riser Front Brake Shimano 445 hydraulic discs 160mm rotors Rear Brake Shimano 445 hydraulic discs 160mm rotors Brake Levers Shimano 445 Rims Giant CR70 DW aluminium Front Hub Formula Rear Hub Formula Spokes Stainless Steel Tyres Kenda Nevegal 26x2.1" Saddle Giant Cross Trail D2 Seatpost Giant Connect Pedals Giant platform CANNONDALE Trail SL 2 Cena: 600£ Frame: Trail SL SAVE with 1.5" head tube, disc specific Forks: Exclusive RST Deuce Air with 100mm travel and 1.5" alloy steerer Rear Derailleur: Shimano XT Shadow long cage Front Derailleur: Shimano Deore Shifters: Shimano SLX Chainset: Shimano Deore Bottom Bracket: Shimano Deore Chain: Shimano HG53 Headset: Cane Creek 1.5" semi-integrated Stem: Cannondale C4 Handlebars: Cannondale C4 with 20mm rise Front Brake: Shimano M486 with 160mm rotor Rear Brake: Shimano M486 with 160mm rotor Brake Levers: Shimano M486 Rims: Maddux DC 3.0 Disc with eyelets 32 hole Front Hub: Shimano M525 32 hole Rear Hub: Shimano M525 32 hole Spokes: CN 15G with brass nipples Tyres: SCHWALBE BLACK JACK Saddle: Cannondale Stage with steel rails Seatpost: Cannondale C4 31.6mm Rockrider 8.1 Cena 549£ 1 Frame Double-thickness 8 series competition 6061 T6 aluminium frame; racing geometry; 1.85 kg in size M. Lightweight and resistant. Its geometry offers an ideal combination for climbs and descents. Available in 5 sizes: S; M; L; XL 2 Fork New Rock Shox RECON Silver TK 100 mm fork Remote Lock-Out on handlebars. Effective rebound adjustment, can be locked in place with a half turn of the lever. 3 Suspension / 4 Drive train SRAM X7 front derailleur SRAM X7 rear derailleur; 9 speeds; Push pull SRAM X5 levers. Shimano Deore M590 22x32x44 crankset with SRAM PG950 11x32 9-speed cassette. Very reliable and efficient drive train, even in extreme conditions. 5 Brakes TEKTRO AURIGA COMP hydraulic disc brakes with 160 mm rotors. Powerful, progressive in any circumstance 6 Handlebar Comp 600/ 640mm raised handlebar, oversize diameter for greater durability. The position is higher to provide more control and comfort without affecting performance. 7 Stem Rockrider Comp stem, oversize diameter, for more durability. 8 Steering Aheadset headset by VP. 9 Saddle New Rockrider COMP saddle by Velo 10 Seatpost Rockrider COMP seat post 11 Wheels Rockrider Comp 32 hole rims by Rigida Hub JT D041/D142, 2 mm stainless steel spokes Sealed bearings. 12 Tyres New Michelin country trail tyre Tak jak pisałem Trudno nam cos znaleźć dla dziewczyny. Pomyśleliśmy o normalnym rowerze rama s. Wrost 167, waga 57. Gigant talon 2 2013 Cena 600£ Frame ALUXX-Grade Butted Aluminium Forks RockShox XC 30 Coil w/ lock-out, 100mm travel Rear Derailleur Shimano XT Shadow, 10-speed Front Derailleur Shimano Deore Shifters Shimano Deore, 30 speed Chainset Shimano M522 24/32/42 Bottom Bracket Shimano ES25 Octalink Chain KMC X-10 Freewheel Shimano HG62 11-34t Headset FSA Stem Giant Sport Alloy, 7 degree rise Handlebars Giant Connect XC, 15mm rise, 690 x 31.8 Front Brake Shimano M395 Hydraulic Disc, 180mm rotor Rear Brake Shimano M395 Hydraulic Disc, 160mm rotors Brake Levers Shimano M395 Rims Giant CR70 double wall Aluminium Front Hub Giant Tracker Sport, 32h Rear Hub Giant Tracker Sport, 32h Spokes Stainless Steel 14G Tyres Schwalbe Rapid Rob 26x2.25 Saddle Giant Performance MTB Seatpost Giant Sport Alloy, 30.9 Pedals MTB Caged, Resin/Steel Trek 4900 Cena 599£ Sizes: 13.5", 15.5", 17.5", 18.5", 19.5", 21.5", 23.5" Frame: Alpha Gold Aluminium w/semi-integrated head tube, butted and hydroformed tubing, internal front derailleur cable routing, replaceable derailleur hanger Fork: SR Suntour XCR-RL w/coil spring, preload adjustment, remote lockout, 100mm travel Rear Shock: 0 Wheels: Shimano M475 aluminium hubs w/Bontrager AT-850 32-hole double-walled rims Front Tyre: Bontrager XR2, 26x2.2" Rear Tyre: Bontrager XR2, 26x2.2" Shifters: Shimano Deore, 10 speed Front Derailleur: Shimano Deore Rear Derailleur: Shimano Deore XT Shadow Chainset: Shimano M552, 42/32/24 Cassette Shimano HG62 11-36, 10 speed Chain: Not Specified Bottom Bracket: 0 Front Brake: Avid Elixir 1 hydraulic disc brakes Rear Brake: Avid Elixir 1 hydraulic disc brakes Brake Levers: Avid Elixir 1 hydraulic disc brakes Saddle: Bontrager Evoke 1 Seat Post: Bontrager SSR, 31.6mm, 12mm offset Handlebars: Bontrager Low Riser, 31.8mm, 15mm rise, 9 degree sweep Grips: Bontrager Race Stem: Bontrager Race Lite, 31.8mm, 7 degree Headset: 1-1/8" threadless, semi-integrated, semi-cartridge bearings Pedals: Wellgo nylon platform Extras: Rack mounts Weight: Not Specified Jeździć będziemy do pracy, a wolnym czasie lasy, nie duże góry. Mam nadzieje ze posta napisałem ok, bo ostatni został wywalony do śmietnika :-). Dziekuje za pomoc.
