[Rower] Specialized Hardrock Sport Disc czy Unibike Evolution
Omv
Otóż mam dylemat który z tych rowerow wybrać:
Specialized Hardrock Sport Disc za 1549 zł:
Rama:
Specialized A1 Premium Aluminum, fully butted, formed TT, Double ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable hanger, disc only
Widelec:
SR Suntour SF11-XCM-V3-26-DS-MLO, 80mm, 1pc. alloy lower, 30mm Hi-Ten stanchions, mechanical LO, coil/mcu spring w/ preload adj., spring assisted seals
Stery:
1-1/8" threadless, loose ball
Mechanizm korbowy:
CRANKSET: SR SunTour, Octalink spline / CHAINRINGS: 42S x 32S x 22S replaceable
Wkład suportu:
Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
Przednia przerzutka:
Shimano Altus, 34.9mm clamp
Tylna przerzutka:
Shimano Alivio, 9sp direct mount long cage
Manetki:
Shimano Acera SL, 8sp rapid fire trigger
Kaseta:
SRAM PG-820, 8-speed, 11-32t
Łańcuch:
KMC X8 w/ reuseable Missing Link
Przednia piasta:
Forged alloy, hi/low flange, double sealed, ground race, machined disc mount and flange, QR, 32h
Tylna piasta:
Forged alloy, mid flange, double sealed, ground race, machined disc mount and flanges, cassette, QR, 32h
Przedni hamulec:
Avid BB5, mechanical disc, 160mm G2 Clean Sweep rotor
Tylny hamulec:
Dźwignie hamulcowe:
Alloy, linear pull
Obręcze:
Alex RHD 26", alloy double wall, pinned w/eyelets, 32h
Opony:
FRONT TIRE: Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead REAR TIRE: Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
Kierownica:
Alloy riserbar, 25mm rise, 8 degree back sweep, 6 degree up
Wspornik kierownicy:
3D forged alloy, 4 bolt, 10 degree rise, 25.4mm clamp
Wspornik siodła:
Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
Siodło:
Specialized XC, Body Geometry, 143mm width, front and rear bumpers
Chwyty kierownicy:
Specialized Enduro, dual compound Kraton, no flange, 131mm
Pedały:
Composite platform, toe clip compatible, 9/16" w/ reflectors
Czy może unibike evolution?
Ktory rower to lepszy wybór
