[Rower] Prośba o pomoc w wyborze: Bulls Copperhead 3 2016 vs Cube LTD Race 2016
bigmaras
Zwracam się z prośbą o pomoc w wyborze roweru w okolicach 4,5k
Rama 18, koła 27,5
Znalazłem dwóch kandydatów:
1) Bulls Copperhead 3 2016
Category Hardtail
Area of use XC--Marathon--Tour
Frame 7005 superlite aluminium, triple butted, smooth welded
Frame Size 46 cm inny rozmiar na pozostałych aukcjach
Weight ~ 11,5 kg
Fork BULLS Lytro, 100 mm, remote lockout, E-Thru
Rear derailleur Shimano Deore XT RD-M8000 GS, 11 -speed, shadow plus
Front Derailleur Shimano Deore XT FD-M8020-E
Shifters Shimano Deore XT SL-M8000
Handle Shimano FC-MT700, 36/26T - PRESS FIT
Cassette Sprockets Shimano Deore XT CS-M8000, 11-40T
Brakes Shimano BR-M447, hydraulic disc, 180/160 mm
Handlebar BULLS
Stem BULLS
Seat post BULLS
Saddle BULLS
Hubs Formula
Rims BULLS XC-21
Wheel size 27,5 Zoll
Tyres Schwalbe Rocket Ron Evolution 27,5 x 2.25
Pedals Wellgo
2) Cube LTD Race 2016
Rama: Aluminium Lite, AMF, ARG, Internal Cable Routing, Easy Mount Kickstand Ready, Tapered Headtube, PressFit BB
Kolor: blackline
Rozmiar: 27.5: 16", 18" // 29er: 17", 19", 21", 23"
Amortyzator: Manitou Marvel TS Air, Remote Lockout, 100mm
Stery: FSA Orbit 1.5E ZS, Top Zero-Stack 1 1/8" (OD 44mm), Bottom Zero-Stack 1 1/2" (OD 56mm)
Mostek: CUBE Performance Stem Pro, 31.8mm
Kierownica: CUBE Rise Trail Bar, 700mm
Gripy: CUBE Performance Grip
Przerzutka tył: Shimano XT, RD-M8000-DGS, ShadowPlus, 11-Speed, Direct Mount
Przerzutka przód: Shimano XT, FD-M8025-D, Direct Mount, Down Swing
Manetki Shimano XT SL-M8000-B-I, Direct Attach
Hamulec: Shimano BR-M506, Hydr. Disc Brake (180/160)
Korba: Shimano XT, FC-M8000, 36x26T, 175mm
Kaseta: Shimano XT CS-M8000, 11-40
Łańcuch: Shimano CN-HG600-11
Koła: rims DT CSW MA 1.7 / 1.9
Piasta przód: Shimano Deore HB-M615, Centerlock
Piasta tył: Shimano Deore FH-M615, Centerlock
Opona przód: Schwalbe Tough Tom Active, 2.25
Opona tył: Schwalbe Rapid Rob Active, 2.25
Pedały: CUBE Aluminium MTB
Siodło: CUBE Active 1.1
Sztyca: CUBE Performance Post, 27.2mm
Zacisk sztycy: CUBE Varioclose, 31.8mm
Waga: 12.6 kg
Czy ktoś z forumowiczów mógłby za i przeciw przedstawić? Ewentualnie alternatywę w tym budżecie?
Z góry dziękuje za pomoc.
Jeszcze jeden kadydat mi się rzucił w oczy w tym budżecie:
3) Haibike rower FREED 7.20
Rama Aluminium 6061
Amortyzator tylny brak
Widelec Suntour Epixon 9 RL-R, 100mm, powietrze-olej
Przerzutka tylna Shimano Deore XT M 781
Przerzutka przednia Shimano Deore XT M781, Direct Mount
Liczba biegów 30
Manetki Shimano Deore XT SL-M 780, Rapidfire
Mechanizm korbowy Shimano Deore XT M 782, 40-30-22 zęby
Wkład suportu Shimano Press Fit SM-BB 71
Hamulce p/t Magura MT 4 180mm/180mm
Dźwignia hamulca Magura MT 4
Kaseta/wolnobieg Sram PG 1020 11-36 zębów, 10 biegów
Łańcuch KMC X10
Opony p/t Schwalbe Racing Ralph Performance, 27,5x2,25, wentyl AV
Obręcze Ryde DB 19
Piasty p/t XLC Alu Disc
Szprychy 2,0mm czarne
Stery FSA No. 57, A-Head, 1 1/8'', półzintegrowane
Kierownica Haibike Top-Flatbar, oversize, 720mm
Wspornik kierownicy Haibike Alu A-Head
Chwyty/owijka XLC SPORT
Siodło Haibike MTB
Wspornik siodła Haibike 31,6mm
Pedały Wellgo, M224G
Błotniki brak, można dokupić osobno
Oświetlenie brak, można dokupić osobno
Specyfikacja inne dopuszczalna waga 120kg
Nie ma innych za, a są nawet przeciw : brak taperowanej główki ramy i sztywnej ośki z przodu, przednia przerzutka i manetki o dwie grupy niżej.
Z tzw. kosmetyki : niegładzone spawy ( niby drobiazg, ale niektórzy zwracają na to uwagę - czasem już po zakupie ) i pancerze pod górną rurą.
Poza tym koła 27,5 " są tylko w dwóch najmniejszych rozmiarach i cena z wysyłką to 4,8 k.
Sam widzisz, że Bulls tańszy o ponad 6 stów ( uwzględniając koszty wysyłki ) jest po prostu zdecydowanie lepszy, bo ma wszystko to, czego nie ma Canyon.
Cube ma te budżetowe ramy jakieś niedopracowane - gładzone spawy przy podsiodłówce, a przy główce już nie i do tego te mocowania pancerza tylnego hamulca z lewej strony ( detale, ale rzucają mi się w oczy ).Poza tym tak jak Canyon nie ma sztywnej ośki z przodu.
Tym samym : Ladies and gentelmen, the winner is Bulls :icon_cool:
Dziękuje wszystkim za pomoc, w takim razie poszperam jeszcze trochę w sklepach przez majówkę i zakupie najprawdopodobniej tego Bullsa. Powiedzcie mi proszę jeszcze tylko jak z serwisem tego w Polsce, jest w ogóle? Macie jakieś namiary na sprawdzone sklepy z tą marką, nie muszą być w Polsce, aby tylko mieli możliwość wysyłki do PL?
Nie wiem jakie reguły panują na forum ale jeżeli nie można w wątku to proszę o pm.
